Permisson Problems
Forum Windows Vista : Vista General Discussion - Permisson Problems
Hey THW:
I have reformatted my regular hard drive (the os hd) multiple times throughout the years. For the last 3 formats, my media hard drive has retained the same info on it. Permissions across 2 instances of xp, and vista have remained the same. Until I installed Windows 7. Permissions are completely screwed up, I can't even open my movies; music whatever. I have to manually go in, it tells me i don't have permission to see the security settings bla bla..I set it to administrator like it should, then i can alter the traits.
Why is it doing this? There were no problems before, now it's horrendous. Is there some way i can Mass Default the permissions on my media hard drive. (since it says no one is allowed permissions until i tell it I have permission.)
Thanks a ton.
I posted this here because i thought it might not just be a Windows 7 thing, maybe theres another answer.
Sponsored Links
Are you using WIndows 7 as your only OS or are you trying to access the same shares from both Windows 7 and XP?
Reply to GhislainG
windows 7 is the only os installed.
Reply to iceman845
Are you taking ownership of all folders and replacing owner on subcontainers and objects? If that works, then you should be able to set permissions and they shouldn't change after a reboot.
Microsoft clearly indicate on the Windows 7 download page that it should only be used for testing purposes, not as the main OS. That doesn't mean that you'll run into issues, but it hasn't yet been fully tested. If you keep on having issues, you should report them to Microsoft (as per the Windows 7 agreement).
Reply to GhislainG
I can get the permissions to "stick" after reboot (to the individual files). When I apply the properties to the music folder, it doesn't apply them all the files, only some.
The fact that Windows 7 is my only OS is irrelevant. If anything, I'm helping them out by trying to access my own media and failing. And yes, I have notified them per the Windows 7 agreement.
Reply to iceman845
Out of curiosity, what's different with the music folder? Is it controlled through an application that has it's own security policies?
Reply to GhislainG
Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Permisson Problems
There are 1192 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
