I have a Antec SX1000II SOHO full tower server case(had it for close to 4 years now lol) and i'm wondering what's the best method for cooling my hardware/case.
______________________________________
To give you an idea of my current setup...
Antec SX1000II SOHO full tower case
Ultra X-Finity 600w PSU (front intake and rear exhaust)
GA-965P-S3 motherboard
Intel Core 2 Duo e6300 @ 2.4 ghz (overclocked obviously)
Thermaltake BigTyphoon 5 (CL-P0114) cpu cooler
BFG 7600GT OC video card
2x 1 Gb Corsair XMS2 6400 ddr2 memory (800 mhz)
2x 320 Gb Seagate sata harddrives (7200.10)
1x 500 Gb Maxtor sata harddrive (relabeled seagate 7200.10)
Standard 10x DVD-RW Rom
1x 2 port firewire expansion card
Built in cooling available in case...
2x Rear 80mm (both are located behind cpu socket area)
3x Front 80mm (1 at bottom, 1 in front of first 3.5 drive area, 1 in front of 2nd 3.5 drive area)
Fans and cooling available...
4x Powmax Typhoon 80mm Cooling fan (temp sensor and capable of 21.5 CFM)
1x SCYTHE KAMA BAY SCKB 1000 120mm Fan (takes up 3 Bays - 5.25 in. - 30.5 CFM)
3x Expansion slot coolers (16 CFM)
Also an assortment of 80mm Case cooling fans... unknown CFM ratings...
What fan arrangement will yield the best cooling method for my hardware? I obviously lack a top blow hole (with exception of the PSU which has front to back fans) and side panel cooling options (unless I were to do some modding :/).
I'm hoping, and am pretty sure, that some of you have encountered this case before or something close to it and that you'll be able to give me suggestions as to what the best fan arrangement would be... Thanks for your time!
