Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems with Direct3d and drirectdraw
Forum Windows XP : Windows XP General Discussion - Problems with Direct3d and drirectdraw
sorry if this isnt in the right place but i was wondering if anyone can help me. I recently Got Call of duty world at war and up until last night i couldn't get it to work and finally it did(reinstalled my video card drivers and direct x for the 300th time) until i had a VPU recovery error. Well its the next day and the game is crashing again. I've sent multiple emails to activision asking them for assistance and this is where i seem to have stumped them.
I found out last night that when i run the directdraw and direct3d tests in the diagnostic tool they show up error less. After i run the game and it crashes while loading a map i do the same Dxdiag test and get these errors :
DirectDraw test results: Failure at step 17 (SetDisplayMode to 640x480x16): HRESULT = 0x80004001 (Not implemented)
Direct3D 7 test results: Failure at step 39 (SetDisplayMode to 640x480x16): HRESULT = 0x80004001 (Not implemented)
Direct3D 8 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x88760827 (error code)
Direct3D 9 test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8876086c (error code)
Restart the computer and everything is back to what seems to be normal. im going to post my dxdiag as well hopefully someone can help me come up with a reason for this.
System Information
Time of this report: 2/26/2009, 14:19:43
Machine name: ALLAJIHAD
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: P5E
BIOS: BIOS Date: 08/04/08 11:36:55 Ver: 08.00.12
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs)
Memory: 2048MB RAM
Page File: 410MB used, 3528MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: The tests were cancelled before completing.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 4800 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x9442)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9442&SUBSYS_025E1043&REV_00
Display Memory: 1024.0 MB
Current Mode: 1680 x 1050 (16 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6903 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/13/2009 23:47:44, 323584 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 1/14/2009 02:14:01, 3455488 bytes
Device Identifier: {D7B71EE2-D702-11CF-0469-5422A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x9442
SubSys ID: 0x025E1043
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: Envy24 Family Audio (WDM)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1412&DEV_1724&SUBSYS_170514C3&REV_01
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: Envy24HF.sys
Driver Version: 5.12.0001.3653 (English)
WHQL Logo'd: Yes
Date and Size: 11/30/2007 22:18:42, 651712 bytes
Other Files:
Driver Provider: VIA - IC Ensemble, Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 96000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: All tests were successful.
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
ICE MIDI External Port, Hardware (Kernel Mode), Input, No DLS, External
ICE MIDI External Port, Hardware (Kernel Mode), Output, No DLS, External
Envy24 Family Audio (WDM), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
ICE MIDI External Port [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
ICE MIDI External Port [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
Test Result: Not run
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2937
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 13:45:37, 59520 bytes
| Driver: usbd.sys, 8/4/2004 04:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/13/2008 14:18:00, 52480 bytes
| Driver: kbdclass.sys, 4/13/2008 13:39:47, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/13/2008 19:13:20, 40840 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC016
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/13/2008 13:39:47, 23040 bytes
| Driver: mouhid.sys, 8/4/2004 04:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: The tests were cancelled before completing.
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay8 TCP/IP Service Provider: Hamachi - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 134.5 GB
Total Space: 610.5 GB
File System: NTFS
Model: WDC WD6400AAKS-65A7B0
Drive: D:
Free Space: 22.0 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD800JB-00JJA0
Drive: E:
Model: HL-DT-ST DVD-ROM GDR8164B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 13:40:46, 62976 bytes
System Devices
Name: Intel(R) X38 Express Chipset PCI Express Root Port - 29E1
Device ID: PCI\VEN_8086&DEV_29E1&SUBSYS_00000000&REV_01\3&11583659&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 13:36:44, 68224 bytes
Name: Intel(R) X38 Express Chipset Processor to I/O Controller - 29E0
Device ID: PCI\VEN_8086&DEV_29E0&SUBSYS_00000000&REV_01\3&11583659&0&00
Driver: n/a
Name: Intel(R) ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_00000000&REV_02\3&11583659&0&E4
Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_00000000&REV_02\3&11583659&0&E2
Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_00000000&REV_02\3&11583659&0&E0
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_82771043&REV_02\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 11:36:05, 144384 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_82771043&REV_02\3&11583659&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:35, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 19:12:08, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:37, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/13/2008 19:11:54, 7168 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_82771043&REV_02\3&11583659&0&EF
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_82771043&REV_02\3&11583659&0&D2
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 13:45:35, 20608 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_82771043&REV_02\3&11583659&0&D1
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_82771043&REV_02\3&11583659&0&D0
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_82771043&REV_02\3&11583659&0&EA
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_82771043&REV_02\3&11583659&0&E9
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_82771043&REV_02\3&11583659&0&E8
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_82771043&REV_02\3&11583659&0&FB
Driver: n/a
Name: Intel(R) ICH9 2 port Serial ATA Storage Controller 2 - 2926
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_82771043&REV_02\3&11583659&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 15:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 13:40:29, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 13:40:30, 96512 bytes
Name: Intel(R) ICH9 4 port Serial ATA Storage Controller 1 - 2920
Device ID: PCI\VEN_8086&DEV_2920&SUBSYS_82771043&REV_02\3&11583659&0&FA
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_2916&SUBSYS_00000000&REV_02\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 13:36:41, 37248 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_92\3&11583659&0&F0
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_197B&DEV_2368&SUBSYS_824F1043&REV_00\4&332B0EE8&0&00E4
Name: Envy24 Family Audio Controller WDM
Device ID: PCI\VEN_1412&DEV_1724&SUBSYS_170514C3&REV_01\4&19ABE7DE&0&10F0
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 11:45:14, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 12:19:42, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0001.0904 (English), 7/9/2004 03:27:28, 48512 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/13/2008 17:12:46, 23552 bytes
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.0000.0900 (English), 12/11/2002 23:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\Envy24HF.sys, 5.12.0001.3653 (English), 11/30/2007 22:18:42, 651712 bytes
Driver: C:\WINDOWS\System32\Audio3D.dll, 0.00.0000.0000 (English), 11/16/2004 09:29:28, 254000 bytes
Driver: C:\WINDOWS\System32\A3D.dll, 0.00.0000.0000 (English), 11/16/2004 09:29:28, 254000 bytes
Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_81F81043&REV_12\4&279E7BDF&0&00E2
Driver: n/a
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&19ABE7DE&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 13:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 13:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 13:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 13:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 08:46:40, 6400 bytes
Device ID: PCI\VEN_1002&DEV_AA30&SUBSYS_AA301043&REV_00\4&16A387FF&0&0108
Name: ATI Radeon HD 4800 Series
Device ID: PCI\VEN_1002&DEV_9442&SUBSYS_025E1043&REV_00\4&16A387FF&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6903 (English), 1/14/2009 02:14:01, 3455488 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0016 (English), 1/13/2009 22:43:12, 53248 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6903 (English), 1/13/2009 23:47:44, 323584 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0407 (English), 1/13/2009 22:37:08, 577536 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 1/13/2009 23:36:06, 26112 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0636 (English), 1/13/2009 23:22:33, 4009152 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0010.0211 (English), 1/13/2009 23:05:42, 2500224 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 10/29/2008 17:13:33, 180720 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dat, 1/13/2009 23:05:09, 3107788 bytes
Driver: C:\WINDOWS\system32\ativva5x.dat, 1/13/2009 23:05:09, 3107788 bytes
Driver: C:\WINDOWS\system32\ativva6x.dat, 1/13/2009 23:05:09, 887724 bytes
Driver: C:\WINDOWS\system32\amdpcom32.dll, 6.14.0010.0019 (English), 1/13/2009 22:50:08, 48640 bytes
Driver: C:\WINDOWS\system32\atiadlxx.dll, 6.14.0010.1023 (English), 1/13/2009 22:44:17, 110592 bytes
Driver: C:\WINDOWS\system32\ativvaxx.cap, 2/26/2009 14:18:51, 79008 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 1/13/2009 23:32:31, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 1/13/2009 22:44:05, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 11:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4218 (English), 1/13/2009 23:34:00, 598016 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4177 (English), 1/13/2009 23:35:38, 155648 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2545 (English), 1/13/2009 23:36:29, 196608 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.15.0006.0001 (English), 1/13/2009 23:36:15, 151552 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2513 (English), 1/13/2009 23:35:56, 43520 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0093 (English), 1/13/2009 22:45:52, 401408 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 8/31/2007 09:20:49, 7167 bytes
Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.3300.42872 (English), 1/13/2009 23:49:05, 425984 bytes
Driver: C:\WINDOWS\system32\Amdcaldd.dll, 6.14.0010.0158 (English), 1/13/2009 21:34:00, 3227648 bytes
Driver: C:\WINDOWS\system32\amdcalrt.dll, 6.14.0010.0158 (English), 1/13/2009 21:36:37, 45056 bytes
Driver: C:\WINDOWS\system32\amdcalcl.dll, 6.14.0010.0158 (English), 1/13/2009 21:36:30, 45056 bytes
Driver: C:\WINDOWS\system32\atibrtmon.exe, 2.00.0000.0000 (English), 10/21/2008 13:51:43, 118784 bytes
Driver: C:\WINDOWS\system32\atiok3x2.dll, 6.14.0010.8395 (English), 1/13/2009 23:53:11, 286720 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.8395 (English), 1/14/2009 00:46:13, 11591680 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4006 (English), 1/13/2009 22:37:45, 307200 bytes
Driver: C:\WINDOWS\atiogl.xml, 11/20/2008 22:26:10, 15362 bytes
Driver: C:\WINDOWS\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 10/21/2008 12:40:00, 45056 bytes
Driver: C:\WINDOWS\system32\ATIODE.exe, 1.00.0000.0001 (English), 10/21/2008 12:40:00, 81920 bytes
Driver: C:\WINDOWS\system32\ATIODCLI.exe.manifest, 9/29/2008 16:22:29, 529 bytes
Driver: C:\WINDOWS\system32\ATIODE.exe.manifest, 10/3/2008 16:48:01, 527 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:51 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 04:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 04:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:17 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:17 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:09:20 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:09:19 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:18 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 04:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:41 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:02 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/26/2009 14:15:46 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/26/2009 14:15:40 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/26/2009 14:15:41 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/26/2009 14:15:42 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/26/2009 14:15:42 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/26/2009 14:15:42 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/26/2009 14:15:43 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/26/2009 14:15:43 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/26/2009 14:15:44 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/26/2009 14:15:44 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/26/2009 14:15:46 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/26/2009 14:15:46 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/26/2009 14:15:47 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/26/2009 14:15:47 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/26/2009 14:15:47 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/26/2009 14:15:45 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/26/2009 14:15:45 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/26/2009 14:15:45 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:52 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 04:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/13/2008 19:11:56 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 19:12:10 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:49 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:51 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/13/2008 19:11:52 498742 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 8/17/1998 04:21:54 11776 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:56 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:42 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:11:59 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:11:53 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 15:44:28 221184 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:03 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 12:21:32 733696 bytes
quartz.dll: 6.05.2600.5596 English Final Retail 5/7/2008 00:12:40 1288192 bytes
quartz.vxd: Final Retail 8/17/1998 04:21:56 5672 bytes
strmdll.dll: 4.01.0000.3937 English Final Retail 10/3/2008 05:02:42 247326 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 8/17/1998 04:21:56 10240 bytes
iac25_32.ax: 2.00.0005.0054 English Final Retail 6/23/2000 13:06:08 192000 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 6/22/2000 12:49:24 842240 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/13/2008 19:11:55 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/13/2008 19:11:55 338432 bytes
ir50_32.dll: 5.2819.0015.0056 English Final Retail 6/23/2000 09:36:48 745984 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/13/2008 19:11:55 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/13/2008 19:11:55 183808 bytes
ivfsrc.ax: 5.11.0015.0056 English Final Retail 6/22/2000 17:11:56 145408 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:01 203776 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/13/2008 11:16:36 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:42 129536 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/11/2002 23:14:32 4096 bytes
stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 03:27:28 48512 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 13:39:51 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/13/2008 13:39:53 4352 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/11/2002 23:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 03:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 03:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 03:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 14848 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:42 118272 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 14976 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/13/2008 19:12:01 1428992 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 16384 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:42 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:01 16896 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 15:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 03:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 18688 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/13/2008 19:12:10 50688 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 03:26:38 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5596
RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0068
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5596
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5596
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5596
Indeo® Video 5.11 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2819.0015.0056
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Indeo® Video 5.11 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2819.0015.0056
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5596
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
Internal LMRT Renderer,0x00800001,1,0,LMRTREND.dll,6.00.0004.0827
AsyncEx,0x00200000,0,1,AsyncEx.ax,
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
File Source (MP3),0x00400000,0,1,MP3Source.ax,
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5596
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1133
TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0001
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5596
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1133
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5596
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1133
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5596
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5596
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,vsfilter.dll,1.00.0001.0004
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.00.0001.0004
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Cutlist File Source,0x00200000,0,1,qcut.dll,6.00.0002.0902
AC3Filter,0x40000000,1,1,ac3filter.ax,1.03.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5596
.RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1133
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,6.00.0013.0068
Indeo® Audio Software,0x00500000,1,1,iac25_32.ax,2.00.0005.0054
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1133
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1133
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
URL StreamRenderer,0x00600000,1,0,LMRTREND.dll,6.00.0004.0827
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.2600.5512
IVF source filter,0x00600000,0,1,Ivfsrc.ax,5.11.0015.0056
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0068
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5596
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5596
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5596
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1133
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5596
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5596
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5596
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5596
Indeo® Video 4.5 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® Video 4.5 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2819.0015.0056
Indeo® Video 5.11 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2819.0015.0056
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5596
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Ligos Indeo® Video 3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Ligos Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Ligos Indeo® Video 5.11,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Ligos Indeo® Video Raw R1.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5596
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5596
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5596
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5596
Audio Capture Sources:
Envy24 Family Audio (WDM),0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
ICE MIDI External Port,0x00200000,1,0,quartz.dll,6.05.2600.5596
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming Capture Devices:
ICE MIDI External Port,0x00200000,3,2,,5.03.2600.5512
Envy24 Family Audio (WDM),0x00200000,4,2,,5.03.2600.5512
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
Envy24 Family Audio (WDM),0x00200000,1,0,quartz.dll,6.05.2600.5596
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5596
DirectSound: Envy24 Family Audio (WDM),0x00200000,1,0,quartz.dll,6.05.2600.5596
WDM Streaming System Devices:
Envy24 Family Audio (WDM),0x00200000,16,3,,5.03.2600.5512
Sponsored Links
There are 1355 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
