Tom's Hardware > Forum > Windows Vista > Vista General Discussion > [Solved] Vista machine can't connect when XP machine is already running
Forum Windows Vista : Vista General Discussion - [Solved] Vista machine can't connect when XP machine is already running
Best answer from GhislainG.
I've searched around many sites and am at wit's end.
I have a Linksys WRT54gs-Speedbooster router. My machine is a Vista gaming system, the roommates (dinosaur) is XP sp2. I also have a mobile device that can connect to the wireless. Both machines are hard wired. Up until the last 2-3 weeks, my roommmate, who plays SL all the time, I could turn on my Vista machine and log onto the internet. Now if his machine is on before I get home, I can not access the internet with my Vista or Mobile Device.
Now it gets even more tricky. If I unplug his computer from the router, reboot my Vista and mobile device both connect to the internet, and can plug roommates XP back in and he is connected to the internet without a reboot. I've checked to see if his Firewall is off. It is. He's running PC Tools AV.
I attempted to turn on my Firewall to see what would happen and the same thing happened to him. He was unable to connect to the internet until I turned my Vista firewall off.
It seems to me that there is a change on his computer that is not allowing my Vista and Mobile device to access the router, even though when I log on and access the LELA it shows green from my computer to the router, and router to the internet(cable modem) is green.
Update: Now in the last 5 days my router is showing my vista machine Red Lined even though we've unplugged the XP machine and I can connect (Vista) no problem.
Think the router is on its last leg or possible a software issue? I've attempted to turn off IPv6 (but it was on before with no problems). This is a new issue. I believe the Linksys WRT54gs is v6 (or v5).
Thoughts?
ipconfig /all will tell you which system is the DHCP server. With your configuration, it should normally be the router, but if his PC has a DHCP service, then you'll have the proof that you're looking for.
Sponsored Links
Do you get a valid IP address (for your network) when his system is connected? Did you check the router's routing tables while he's connected?
Reply to GhislainG
I'll have to check my (Vista) IP when it happens. Though when everything is up and running if I log my mobile off then on (to my secure router), I don't get the IP address in the range I've specified in the router i.e. I should get a 2.101 through 2.105 but I get something completely different 168.192.1.2, so I'm thinking that his computer is assigning the IP's through his DHCP?
If I can pry him off Second Life for more than 2 min I can check what IP he has when his computer is the first on the router and mine after I log on. This would be proof enough that it has something to do with his computer if the IP range is the same as his I'm thinking.
Reply to ernestj3
I also believe that he might have a DHCP service on his PC.
Reply to GhislainG
I'm convinced he is running a DHCP client on his computer and just doesn't know it. Thanks for the advice on the subject. I just wasn't sure if the router could be going bad and not replying fast enough to his computer's IP request from a DCHP so it takes over.
Reply to ernestj3
Best answer
Reply to GhislainG
There are 777 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
