Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » First time builder, looking for opinions/help with rig
Add a reply
 Word :   Username :
Bottom
Author
 Thread : First time builder, looking for opinions/help with rig
Profile: stranger
More Information
Here's what I'm thinking:
UPDATE: See Newegg wishlist for latest rendition
CPU:  Intel Core 2 Duo E6600 Conroe 2.4GHz
CPU Cooler: ARCTIC COOLING Freezer 7 Pro
Mobo: MSI P965 Platinum LGA 775 Intel P965 Express ATX Intel Motherboard
RAM: Patriot eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
Graphics: EVGA 640-P2-N821-AR GeForce 8800GTS 640MB
HD: Western Digital Caviar RE2 WD5000YS 500GB
Case: Antec Performance One P180 Silver cold rolled steel ATX Mid Tower Case
Power: AeroCool ZERODBA ZERODBA-S620 620W Power Supply
I'm looking to build something similar to Day 2 of the System Builder Marathon.  I want this system to last for about 3 or 4 years.  I will eventually run Vista on it (probably later this year), but for now I'll be using XP.  I have a DVD R/W as well as speakers, monitor, keyboard, and mouse.
My main concern is with the Mobo, CPU, graphics combo.  This specific mobo is open box - is this worth the savings?  The other parts were picked on what seems popular (probably not the best way to pick, but hey that's why I'm writing).
After mail in rebates this works out to just under $1100 which is around about what I'm looking to spend.
Related Pr oduct
Profile: member
More Information
that setup looks good the only thing I would question is the motherboard and chipset on it.
I am not familiar with the p965 but the 680i and the p35 are from what I understand the way to go.
I ordered the p5k asus board, gigabyte has a p35 board out as well.
The improved memory controller and other features make it an atractive chipset.
otherwise looks good to me.
there will be price cuts in 6 weeks or so on the chips and you may want to wait to see what other cpu you can get in your budget, and more motherboards may be out by then offering better price points for the p35 also.
Lump
Profile: Ancient Poster
More Information
Switch the psu to a Corsair 520HX. More power, better quality, and it's cheaper after the MIR.
Lumper is right about the mobo, if you wait a couple weeks you'll be able to get a Gigabyte DS3R for ~$180. Here's a review.
I say away from open box items myself. They've been returned by the original owner for whatever reason, and the reason most people return products is that there's something wrong. Granted, since it's still up for sale it's probably fine, but still, you never know. Plus, it's pretty much just a used OEM now. No I/O plate, no box, no manual, and no cables.
Profile: Forum Veteran
More Information
To me, the open box is worth about half the retail price. Or a ridiculously low price + shipping at ebay.
Even then, you need to be knowledgeable to make use of open box items.
However, I think most retailers do guarantee against dead on arrivals.
Get the new ones. Still the "new" one could still be used. There's no taping on the anti-static bag anymore. Especially mobo. They're made in China. There are large fingerprints on the I/O connectors. The back is like it was melted due to overclocking. At least that's my experience with ASUS boards. None of the "new" ones I got was DOA though.
Must change the psu out unless you don't want it to last.
Profile: stranger
More Information
Ok, so I change the power supply to the Corsair 520HX, but I'm still not sure about the mobo.  I don't know if I really need an SLI enabled board, I was looking to spend about $130 on the mobo (flexible either way) - if that happens to be an SLI board, then that's fine.
What about one of these?:
GIGABYTE GA-965P-DS3 LGA 775
MSI P6N SLI-FI LGA 775 NVIDIA nForce 650i SLI
MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i
More Information
Simply put, P965 overclocks cpu & ram at a ratio. Ergo, it needs quality ram to o/c well. 6x0i overclocks cpu or ram independently. It can o/c either or both unlinked or linked. It doesn't need expensive ram to o/c the cpu well.
The ram you picked out is not guaranteed Micron D9 IC - best of overclocking. It may be Elpida chips that overclock better than the Promos which is on almost everything.
If you don't o/c, this doesn't concern you.
In case you o/c, you can get this for cheap & it's Micron D9:
http://www.newegg.com/product/prod [...] 6820231065
Profile: stranger
More Information
Ok, so say I am interested in overclocking.  Would it make more sense to choose a 6x0i board and stick with the cheaper RAM, or spring for the more expensive RAM and use a P965?
More Information
If your budget is tight, yes it would. Otherwise, get the 965P + fancy ram.
More Information
Ram is dirt cheap, you can get a D9-based 2gb kit for $110. I mean, you can get DDR2-1066 for $160! In late December I payed $270 for my Super Talent DDR2-800. Now it's less then half that.
Profile: stranger
More Information
Well I was looking to spend $120-150 on the mobo and about $100 or so on the RAM.  I guess I could just get a cheaper case and throw a little more money on the board - right now the case I have picked out is $130.  Is SLI something that can really extend the longevity of my rig?  For example two years from now, is tossing in a second 8800GTS (assumed to be cheap then) dramatically going to improve things?
Thanks for the help btw
More Information
I agree with apt403, but I bought my valueram before the crazy price drops. I ain't getting anymore other than the PC2-9000 or faster one at a discount. They'll get cheap when DDR3 rolls out.
No, SLI won't prolong the life of a pc. It's a just a way to run 2 cards at the same time & double the performance in most cases. Just like crossfire. I never said anything about life, just overclockability. I'm after that. To be exact, cheap overclockability.
video games kill virtual pets
Profile: enthusiast
More Information
get the P182 for the better cord managment  :twisted:
Profile: stranger
More Information
Quote :
Isn't this more expensive than the case I already have picked out?  Not that I am dead set of the P180 but the P182 wouldn't really help me in terms of my budget.
Profile: stranger
More Information
Add a reply
Google Ads
