Hey Everyone,
So, I've been looking around trying to find the cheapest route of streaming Movies and music to the TVs in my house. I am building up a Linux server running Debian Squeeze that will be the central point for all of my media (my music, movies, photos, web site files, etc.). Also, I want to put the streaming devices on my 5ghz band of my dual band N600 router.
Here is the plan I'm considering:
I am thinking I can purchase these Raspberry Pi PCs to hook up to my TVs. Then, with the use of a USB wireless adapter, I can connect them to my home network.
Now, I need the Pi's to connect to my server to access the media it contains to play through to the TV, but I'm a bit unsure on how I can do this... I've found a few things like the VLC Player program to do the streaming (because it accepts all types of video playback) but how would I access the media on the server? Or, there is this Raspbmc OS software that basically turns the Pi into a little Media Center using a version of XBMC.
The problem with this is on the FAQ page for Raspbmc, someone asks "why is XBMC fuzzy?" which the reply is "XBMC runs the UI at 720p by default on the Raspberry Pi, and uses the GPU to output it at a 1080p resolution. Raspbmc is the only distribution to allow you to disable this. This can be done from Raspbmc Settings" and it leads me to believe that this setup is only good for 720p...? and I'd LIKE 1080p capabilities...
So, my question is... is there another method or setup I can/should use to be able to stream movies from my server to the TV through the Pi? I've been referred to the SAMBA setup several times for the actual server, and was wondering if I can install it on the Pi and access the movies and media on the network? Or, if there is anything else out there or a work around for this streaming setup? Can I just install a Linux distro and the VLC player and be good to go?
Also, is there anyway to stream my Netflix and Amazon Instant Video movies through the Pi? I know they do not support the applications, but I wondered if it were installed on the server or a laptop if the Pi can access it over the network?
Hopefully you guys can lend a hand or point me in the right direction... Thanks to you all for looking!
