Gigabit it's the way to go... Crossover it's required for a PC2PC connection... the switch isnt going to make the connection faster..For remote desktop it's more than enough... Try UltraVNC it's quite fast. Firewire it's fast and low CPU usage but the cable it's on the expensive side... USB it's slow, very cpu dependent and requires a special cable
hmm, yea and no. i would definalty go with gigabit ethernet link, however if it is possible you would be much better off just plugging your laptop into the swicth on your router (especially if it is gigabit). that way your laptop can acess internet if your master system is off.
