Their power supplies are not worth a premium.
I looked at their myths. As an engineer, my opinion is that the explanations are self serving.
I looked at their efficiencies. Since the efficiency is a function of load, their stated efficiencies are worthless. One needs to know the efficiency at the actual load.
I looked at their power consumption calculator. It is impossible to get my system to draw 200W from the wall, yet their calculator suggests a massive power supply.
I liked especially how they made the claim that their PSU was "free" compared to an Antec PSU. You might try to draw 750w continuous 24/365/3. I bet you cannot even draw that much power for 5 minutes. I bet you need additional A/C for that room also. The power cost alone is $2000 for 3 years of operation.
From a practical point of view the power supply that comes with a case will serve most users well. Case cooling will fail to keep up well before the power supply fails to keep up.
A good system builder will have a large bench PSU that he will use to set up a system. He will then install the "proper" sized PSU before delivery.
Engineer here also. I'll let my experiences speak for themselves:
In my own personal machines I have 3 OCZ Powerstreams (no longer made) and 2 PC Power & Cooling PSUs. No failures ever on these (the server and family computers run 24/7 and the PSUs have been carried over from prior builds). In fact, I've never had any premium PSU fail, though I know it happens on occassion.
I have, however, built a lot of systems (close to 100). Sometimes I use the PSU that comes with the cases; more often I use a slightly better but still cheap power supply (say, a $40 Thermaltake for example). In servicing computer I or others have built--to include HP, Dell, Compaq, etc.--I have experienced more bad power supplies than almost ALL other hardware failures combined.
My personal experience is that mass merchandisers use inexpensive power supplies that are barely sufficient when they do work in order to save money. One of the primary reasons to build your own computer is to have absolute control over the components that go in. Your custom machine uses parts that you have carefully selected and expect to perform and last. I've seen too many PSUs fail, often taking a mobo with them, to put my faith in the "economy" of a cheap power supply. At least Dell or HP will replace the computer if it fails under warranty. Can you afford to do that? Are you that much of a gambler? And really, how stable is your computer with the cheap PSU under varying load, temperature, or voltage conditions?
I've paid my dues and learned my lessons on the value of a good PSU. Just don't let the price be your criteria for judging a "good" PSU. there are plenty of expensive junk ones out there also.
