Randomly my pc will freeze up. The screen turns a solid color(grey,black,white,red,tan etc) and continue to loop the last noise made. If there was no noise, it is silent.
Ok so what do you guys think is wrong? Are there tests i can run to see if everything is working properly? What should i do?
IT happens frequently an i want it to stop.
I Built my pc 3 months ago, this happening is scaring the crap out of me.
I've had the exact same thing happen to me, and I haven't figured it out yet. My computer ran great for the first month, but it's been freezing much more often lately. List what your computer specs are, and we'll compare them.
Mine is configured as follows:
Asus Striker II Extreme motheroard with the Nvidia 790i chip set.
2 1-gig Palit 8800GT graphic cards running in SLI
Intel Quad Core 9450 (not overclocked)
Asetek Liqid cooler
2 500-gig Western Digital hard drives (7200rpm) in RAID
4-gig Corsair DDR3 1333 Memory
Windows Vista Ultimate (64bit)
I haven't yet tried a Bios update for the Striker II motherboard, but I've got a feeling that might work.
Also, I've heard of compatability problems with 64-bit Vista and the 8800GT cards.
If it freezes on audio, then your sound card or drivers are suspect. Update the drivers and see if it helps.
There are no compatibility issues with 8800GT cards and 64-bit Vista. I know, because that's precisely what I'm running. There might be some issues with SLI that I don't know about because I'm not running an SLI config.
To the last poster, you might want to consider making sure all of your RAM is installed in matched pairs... especially if you're running in dual-channel mode. It wouldn't hurt to update your BIOS either.
------------------------------Desktop: Windows 7 Professional 64-bit; Intel Q6600 CPU; E-VGA 780i SLI motherboard; E-VGA E-GeForce 8800GT; OCZ Vista 4GB dual-channel kit; Ultra X2 750W power supply; 2 x Seagate Barracuda 7200.11 500GB in RAID 0. Laptop: Acer Aspire 8730-6314;
Reply to Zoron
