Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Outlook Problem Please Help
I run a 64 bit Vista and have had 0 problems with this computer I built 2 years ago. I use my outlook for work.
Now out of the blue I get an error that says "Cannot open outlook window" - what the heck?
I tried putting the CD and using repair function which didn't work, I really don't want to reinstall. It looks like I will have to completely uninstall the entire office suite, then reinstall. Which also means I will have to download several gigabytes of updates, and I'm running out of hard drive space. Any ideas?
Sponsored Links
Backup your .ost file on your HDD and reinstall, IT WONT ADD MORE UPDATES!
------------------------------ Intel core 2 duo e6750 @ 3.3ghz
Asus P5N32-E PLUS SLi nForce
4gb ocz pc 9200
6 satas
Reply to fowang
There are 626 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
