wired v wireless
Forum General Networking : Network General Discussions - wired v wireless
currently our router is in a room on the other side of the house from my room, with a 50ft cable connecting my comp to the router. would I get better speeds with wireless or is wired still the better way to go? theres generally no closed doors between my computer and the router, although there are some walls and whatnot.
------------------------------ Q6600, Gigabyte P35 DS3R, EVGA 8800 640mb Superclocked, Crucial Ballistix 2GB PC6400, Raptor 150GB, 2x Barracuda 500GB SATA, 1x Barracuda 500GB IDE, Zalman 9700, CoolerMaster eXtreme 650W, Antec 900
Sponsored Links
A good wireless router shouldn't slow anything down. I have the ZyXEL X-550, easy to set up including security but Netgear, Buffalo, and Linksys all make good routers. If what you have is working and no one is complaining about wires, seems to be a woman thing hating wires :), you could just keep it as is
Reply to g-paw
nah, no complaints bout the wires. more just something that I thought maybe the wire due to its long length might be slowing down the speeds and if going wireless might speed things up
Reply to mrmark27
As long as you have good ethernet cable, you will not lost any speed under 300ft of cable. however, wireless may be a little slower. Personally, all my computers usually use wired connections, since i have found that wireless will slow down our 20mbps connection
Reply to suvayanr
With a descent wireless network you shouldn't notice any difference in internet perfromance but it is slower for file transfers across the network. If your really curious you can benchmark it with qcheck although it is kind of annoying to sign up to download and let through the windows firewall. Wired connections are either 100 mbps or 1000 mbps with the good stuff a perfect 54 mbps wireless is 26 mbps and you assume it's not perfect so 20 is a good estimate.
Reply to brw02005
Stick with wires. 50 ft is not long enough to cause any problems unless your cable sucks. Wireless introduces all kinds of problems you don't want unless you have to. Like security threats of hackers next door, slower speeds. Finding the perfect settings to get the best throughput. Trust me, don't do it unless you have to.
Reply to Computer_Lots
When you do decide to get a new router it makes sense to get a wireless. Wireless routers will allow you to hard wire usually up to 4 computers but if you need wireless, e.g., for a laptop, you have it.
Reply to g-paw
Tom's Hardware > Forum > General Networking > Network General Discussions > wired v wireless
There are 1219 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
