Tom's Hardware > Forum > Windows XP > Configuration & Customize > System drive letter change help
Hello everyone. I hope someone can help. I just upgraded my "guts" (mobo, ram, cpu) and am trying to get all set up. I installed windows XP on a brand new hard drive on a newly created partition. On the setup screen, it says
C: Partition1 [NTFS]
I left some unpartitioned space on the new drive for a later win xp 64bit version install and I also have another HD that is listed as D: Partition1.
After the install, my system disk drive letter was F: and my other HD letter was E:
I go to disk management and I can change my second HD letter but it won't let me change my system drive letter back to C:
How do I get my system drive letter back to C: ????
Thanks for any help!
Sponsored Links
The partition where Windows is installed cannot be changed easily (a lot of driveletter references needs to be changed). Normally a reinstall is prefered
Reply to mikrev007
There are 495 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
