Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Weird BSOD upon system restart issue
Forum Windows Vista : Vista General Discussion - Weird BSOD upon system restart issue
Ok so for the past month or so I have been having this problem and I figure its about time I figure it out. So whenever I go to shut down or restart my computer running vista it will say "shutting down" and it will get to about the point where the system would normally shut down but then I get a BSOD that lasts no more than half a second and the system reboots. This happens every single time. Keep in mind my system starts up just fine. So in order to turn my computer off I have been holding the power button down until It shuts off.
As of recently my system appears to no longer show the Blue screen when I go to shut my computer down, It will just reboot as if it is skipping the BSOD. This is unfortunate because I can't even read what the BSOD says anymore.
Any suggestions? I really don't want to have to install a fresh install of Vista because I would have alot of files to back up. From what I can gather this is not a hardware issue because my system has passed all the memory and hardware tests I throw at it.
I am also conserned this might be interfering with new installations of applications that require a system restart because it is not restarting correctly. I have even noticed that when I do a restart, or shut it down, the system won't save the new location of desktop icons if I move them.
I just want my computer to be able to go to sleep without having to pull the power on it :(
EDIT: Here are the system specs. I built this system myself about 2 months ago. It has been running just fine most of the time.
-4 gig 2x2gig chips of gskill pi ram
-Q9400 Quad Processor (OC to 3.6 and stable)
-ATI 4870, OC mem to 800 (stock it is 750mhz)
-500 gig harddrive Seagate
-650TX corsair PSU
LG optical drive
Message edited by qwoz on 07-25-2009 at 06:26:25 AM
Sponsored Links
Right click on Computer -> Properties -> Advanced System Settings -> Startup And Recovery Settings -> Uncheck Automatically Restart.
That will give you an opportunity to read the BSOD
Reply to dmroeder
I would reinstall it with the latest drivers from the net :)
Reply to ion_tribe
After doing what dmroeder suggested I was able to determine that the BSOD has to do with "usbhub.sys". Anyone know how to fix it? i'm glad its a usb issue of some kind and not something massive like the processor failing.
Reply to qwoz
Oh I just did some reading online. After unplugging all of my usb devices such as keyboard, mouse, wireless adapter, I tryed a computer shut down and it shut down correctly this time. After doing this i attached usb device at a time and shut down the system to determine what was causing this issue. When I got to keyboard I got the BSOD. So I know the issue is keyboard related. From what I remember, Before Service pack 2, this keyboard worked just fine with my system. Any Ideas?
Reply to qwoz
I have been doing a bit of reading too and it sounds like whatever is happening was common with XP as well. Are you actually using a USB hub? How many devices do you have connected to USB?
The issue may not be the keyboard, but how many devices you have plugged in.
I'll do a bit more reading when I'm off work.
Reply to dmroeder
no i am not using a usb hub. One thing that i found interesting is alot of people with this problem are using an asus motherboard like I am. What I ended up doing is I got a new keyboard and now everything is fine. I think it had to do with the keyboard not being compatible with vista SP2. weirdo Microsoft
Reply to qwoz
There are 1216 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
