just got a new mobo from evga and set it up. did the artic siver5 compound replacement on the north and southbridge, as well as on the cpu heatsink. my temps don't seem any better this time round either though--
in nvidia monitor view-- cpu 55c, system 51c, gpu 81c
in bios sytem monitor- cpu 56c, board 50c, mcp (n&sb) 65c
the temp in the room is around 80 degrees
i have the fans set to go 100% if temps over 65
this time when i did the thermal compound replacement i made sure not to move the metallic arm that connects the north and southbridge, and i spread the compound in a thin layer across both bridges. seems that those who do this job well are getting temps around 45-55c.
i didn't do any gaming, just left the computer on for a few hours.
since the temps are around what i got last time, i am hoping that my mobo doesn't die again, since last time it basically died, giving led code 21- power failure i think (HPM init), never booting to bios, and no longer powering one of the fans plugged into the mobo.
i don't see how i can improve on the thermal replacement, since i've printed out the instructions from the forums here and followed them.
basically, i am worried that my mobo might ****** out again with these temps, that hotter summer temps will be problematic, and that i will never be able to overclock down the road if these are my stocktemps.
whaddya think?
whaddya think?
