I am looking at building a new pc my first attempt.
i want to use the computer for my educational use, like word typing, creating web pages, storing wedding pictures (really loads of them), want to store them on dvd, i lalso use programming languages like, visual basic, python etc to make programmes.
and after much trawling through the internet I have come up with the following spec:
AMD Athlon 64 X2 6000+ 3.0GHz
Gigabyte GA M59SLI-S4 AM2
320GB SERIAL ATA II HARD DRIVE
2GB RAM (1GBx2)
LiteOn DH-18A1P-18C 18X DVDRW
Microsoft Windows XP
Can you tell me if the above specification is any good?
Are the computers parts compatible with each other?
would you recommend going with the Athlon AM2 5600x 2 Dual Core CPU instead of the AMD AM2 6000 x 2 Dual Core CPU and save around $50 or so. what will the performance difference be?
what does the SLI stand for on the motherboard?
should i go for 500GB Hard disk?
i have not mentioned any graphics card. how many graphics card can it have?
Thanks
Chris
2GB RAM (1GBx2)
Thanks
Chris
