Point is, the temps on my dads 4300 stayed the same (38-40), and didn't reduce. I'd say his temps are okay, but with a 100 percent worklevel load would really be the test.
Are you letting the mobo do auto fan speed control? I'm pretty sure that if so it targets about 40C and slows the fan down if it falls below that, so that would be normal. I was just saying that if my idle temps were 40C, I'd do some stress testing at stock speed before jumping into OC'ing, especially if an OC high enough to require voltage boost is planned. As I recall, your dad's 4300 OC isn't real aggressive, the OP didn't really say how aggressive he wanted to go. The 120 Extreme is awesome, even if it was a pain to find in stock amonth ago. It seems pretty easy to find these days though.
I believe your correct, it perhaps is turned on (can't remember really, I thought I disabled it). The MSI app has 7 levels for fan settings. When I did use speed fan, and kicked it up to 100 percent, I could see the fan speed change through the case (rear led fan has like a spin affect on it). Also the RPMs are at 2000, but the max is under 2400. So, actually the temps won't really change much. It is using that sunbeam clone HSF that looks like that AC7 pro (6 heat pipes).
Edit:
I do remember if I force the fan to run under 1900 rpms, the temp rises. Really can't jump on the system atm, dad is using it. :lol:
