Yes No
Ads
Tom's Hardware > Forum > Windows Vista > Drivers > Printer help
Printer help
Forum Windows Vista : Drivers Printer help
I have not been able to get my printer to work on my Vista system.
It did work at one time on my Vista machine and does work on my XP machine.
Printer: Epson R1800
I have down loaded the latest drivers from Epson's website.
I have uninstalled all previous drivers before downloading.
After installation, device manager shows two 1394 ports. One and has an exclamation mark next to it.
I am kind of frustrated with my Gateway system in this regard.
BTW the Epson support has been outstanding. ( I think they want you to be able consume their ink, my printer takes 8 cartridges.)
I am on a LAN with my XP machine, come to think of it, maybe that is when my problems started.
Thanks in advance,
Tapeman
Has anyone had this or a similar problem?
Reply to Tapeman
Th OS is x64? or 32....whe you install the driver...disable UAC, windows firewall and antirivus....some times this programs don't permit the correct installation of the drivers.
------------------------------ Installing the CM Hyper 212+
AMD Overclocking Club
Member Rankings: Points, status and badges
Doesn't work? Send me a PM.
Reply to saint19
32 bit.
I have been reluctant to disable my firewall, but I guess I can try it on a trusted site. I am considering hiring a tech to come here and fix it, but being cheap I'll try a little longer on my own.
Reply to Tapeman
if your trying to install and network printer on your computer you need to create a local IP port that the computer can print to, diabling firewalls and anti virus is not required. Google add a network printer! Thats if your printer is attached VIA cat 5 cable or using wireless
------------------------------ i7 2600k, Corsair Obsidian 800D, Corsair XMS3 8GB, Asus GeForce GTX 480, ASUS P8P67 DELUXE, 2 OCZ 120gb SSD's raid0
http://en.lmgtfy.com/?q=how+to+use+goolge
Reply to fowang
There are 1895 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I cannot get my external hard drive fully installed on vista
By nhasian, 1 day ago:
rather than fdisk it is recommended to use Disk Management. Create and format a hard...
Best offers
