Wireless Adapter Help
I want to get a Wireless Adapter I don't care if it is PCI or USB but I want one that's $0-$25 and works with Vista. The main problem is I can't find one that works with Vista.
I want to plug it into a Xp and run the wireless on a Vista Laptop.
3 answers Last reply
More about wireless adapter help
  1. Conceptronic C54Ri... it's PCI, and VISTA compatible it cost's 23€ in portugal... and Conceptronic C54RU it's USB... but i dont have the price of that
  2. Um can I buy that in America?
  3. Probably... if the laptop it's already working under vista and WIFI it's installed you should pick one to your Xp machine that is also vista compatible for maybe a future update to vista i think... conceptronic just in Europe... i think... Another alternative it's Belkin Wireless G USB Network Adapter you can find it at http://www.newegg.com/Product/Product.aspx?Item=N82E16833314011 for 19.99dollars and it's vista compatible. it's USB and has a desktop stand. i have one and it work's great
NICs Wireless Adapter Windows Vista Components Product
