I have a unique situation and needed some assistance. I have a laptop in a remote facility with an audio device attached to it. I have a cable attached from the audio out port of the device to the MIC port of the laptop. I establish an RDP session to the laptop however I am unable to hear or record the sound coming from the remote audio device from the RDP session.
Is there anyway that I can get the audio from the device connected to he remote laptop over RDP session. Or is there a device out there that can transfer audio from a remote device over internet?
Sponsored Links
what are you using to connect to the computer, in messenger it has it's own control for the sound, I've learned the hard way that if the sound won't work to look there before I tear everything apart, maybe the software that you are using has the same issue
Reply to number13
- 0 +
I connect using Remote Desktop protocol.
Reply to bobakin
so there is no way to change the sound devides
Reply to number13
- 0 +
When connected via RDP the only sound option available is Microsoft RDP Redirector driver. Thus only allowing the most basic sound options. I connect record nor hear or utilize anything attached to the Mic or Line-In port on the remote machine.
Reply to bobakin
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Help. Audio issue
There are 1049 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
