SSD - The Performance Upgrade of the Future
[img]problem.jpeg[/img] Hi guys i got a problem in my task bar. The windows are little and small instead of normal ones like this: [img]normal.gif[/img] how can i put it back to normal way help!!!!!!!!! http://i948.photobucket.com/albums [...] normal.gif[/img] http://i948.photobucket.com/albums [...] roblem.jpg
Well, first you need to put the images up on a image hosting site, then put the link in the image tags.
i put the pictures!
I'm at work and can't view the pictures, but it sounds like your resolution changed. Does everything look smaller?
