Is a wireless connection the same as 512kps
i have 12mps wireless connection is this fast enough for tvonpc
1 answer Last reply
More about wireless connection 512kps
  1. It should be. Have you tried moving the router around or building a makeshift antenna to boost the signal? Because I have a cheap router and I get up to 54 Mbps wirelessly, but I usually just hook it up LAN to get 100 Mbps. You can make either an antenna or a dish, and there are numerous ways to make them, all for under $5, some under a dollar.
Internet Applications Wireless Connection Apps
