I had recently upgraded my system from a Windows XP Pro(32 bit) to a Vista Ultimate(64 bit). After installation i am facing the following problems:
1) When i plug my Logitech Z-560 4.1 Surround Sound to my system, i cannot hear any sounds from the rear speakers. Even after going to control panel nad sounds and setting it to quadraphonic sound setup, and can hear that the wizard has detected the rear speakers, there is still no sound from the rear speakers wheever i play any mp3, movies etc. I can however hear sounds from the rear speakers if i enable Sonic Focus on my SoundMax BlackHawk (ver 1.0.0038), but i do not like enabling the option as it makes all the sounds kinda echoey.
2) When i plug my microphone to the front jack and speak, i can hear myself through the speakers. The same happens when i connect a headset. I can hear myself talking through the headset when ever i say anything. There used to be a setting on my SoundMax when i was using Windows XP, but cant seem to find the same setting on my SoundMax BlackHawk in Vista.
I am using an ASUS M3A32-MVP Deluxe/WiFi-AP motherboard with an AMD Phenom 9950 quad core processor.
sounds like you have plugged the mic into the wrong port, is the port you are plugging the mic into red/pink or blue, if its blue then its in the line in!
------------------------------Intel core 2 duo e6750 @ 3.3ghz
Asus P5N32-E PLUS SLi nForce
4gb ocz pc 9200
6 satas
Reply to fowang
well since its the front panel i have only 2 points for audio....one is a green point and the other is a pink point, i pretty much put it into that point . And since my sound controller is SoundMax, any time i plug any cable into any point, it will detect the device and let me know if i have plugged in a right cable or not.
It will come up as working usually, go to the levels tab as shown on the 2nd screen shot and mute the mic, it will unmute in applications that will require the use of it
4gb ocz pc 9200
6 satas
Reply to fowang
