Tom's Hardware > Forum > Overclocking > General Discussions > Help Understanding RAM Overclocking
Forum Overclocking : General Discussions - Help Understanding RAM Overclocking
Hi all, I'm kindda new towards OCing but i sorta know how to increase the clock speed and FSB but each time i reach the mem oc im as blind as a bat , not knowing what to do. i mean what does all those numbers mean and can the latencies be changed with from OCing?
Sponsored Links
always read the stickies first !!!!
mem overclocks as you raise the fsb, the thing you have to worry about is cpu:mem ratio.
like if your fsb is 200mhz and you set your mem to 266mhz your is ratio 3:4
and if your fsb is 200mhz and you set your mem to 400mhz your ratio is 1:2
and so on
its best to keep 1:1 so 200:200
and for latencies, they are a bit complicated. all you need to know is we usually list them with 4 numbers like 4-4-4-12 or 3-3-3-8
the bigger the number the looser the timing, the slower the ram, the easier you can overclock
the smaller the number the tighter the timeing, the faster the ram, the harder you can overclock
leave them in default if you don't know what to do.
Reply to Penryn
There are 535 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
