Yep, another new build post. Appreciate any input
All around new rig. I play games, photo edit etc.
Case: Antec Nine Hundred Black Steel
http://www.newegg.com/Product/Product.asp?item=N82E16811129021
Power Supply: Corsair 620
http://www.newegg.com/Product/Product.asp?item=N82E16817139002
Motherboard: GIGABYTE GA-P35-DQ6 LGA 775 Intel P35
http://www.newegg.com/Product/Product.asp?item=N82E16813128046
CPU: Intel Core 2 Duo E6600
http://www.newegg.com/Product/Product.asp?item=N82E16819115003
Memory: Crucial Ballistix Tracer 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2
http://www.newegg.com/Product/Product.asp?item=N82E16820148076
Graphics: EVGA 768-P2-N831-AR GeForce 8800GTX 768MB
http://www.newegg.com/Product/Product.asp?item=N82E16814130072
Total cost=$1483.00
I have have a hard drive already. Also have a 19" crt but plan on getting a 22" or 24" lcd within the next two months. Thanks in advance for any input.
1 answer Last reply
More about build post input
  1. Good rig - I suggest a cheaper Motherboard, (unless you are VERY keen on OCING THE HELL out of this system)
Homebuilt Systems Product
