Question about Core2Duo overclocking guide
Decad02
45
Hello
I'm trying to OC my e6300 (first time OC). I'm following the guide but I can't find a many of the voltage options:
DRAM/DIMM (v/DIMM)
SB Voltage (vICH)
Those are no where to be seen. The other ones seem to be labeled as "Overvoltage"
My Gigabyte BIOS has (after hitting CTRL F1):
System Voltage Control
DDR2 Overvoltage
PCI-E Overvoltage
FSB Overvoltage
(G) MCH Overvoltage
CPU Voltage Control
Don't see any other voltage options.
CPU Clock Frequency is grayed out, as well, but that may be because I haven't finished doing the other settings. Help would be appreciated.
Thanks
(below are my system specs)
Core2 Duo E6300 Dual Core Processor LGA775 Conroe 1.86GHZ 1066FSB 2MB Retail
Sapphire Radeon X1950 XT 625MHZ PCI-E 256MB GDDR3 Dual DVI-I HDCP HDTV Out VIVO OEM Video Card
Gigabyte GA-965P-S3 ATX LGA775 Conroe P965 DDR2 PCI-E16 3PCI-E1 3PCI SATA2 GBLAN Audio Motherboard
OCZ Gold XTC PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-12 240PIN DIMM Dual Channel Memory Kit
Coolermaster CAC-T05 Centurion 5 Aluminum ATX Tower Case 5X5.25
OCZ GameXStream 700W ATX12V 24PIN SLI Ready Active PFC ATX Power Supply 120MM Fan Black
Arctic Cooling Freezer 7 Pro
Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive
Penryn
30
do some more reading and you'd know:
dram/dimm voltage is ddr2 voltage
sb voltage is the chipset voltage which is MCH (i don't know why gigabyte titled it that)
and dude word of advise, don't mess with chipset and (maybe) memory voltage until you maxed out vcore and fsb.
andybird123
373
the 3rd option on the MIT menu is CPU Host Clock Control - this needs to be set to Enabled to make CPU Host Frequency changeable
Decad02
45
*chuckles* I could read about this stuff forever, if I had the time.
I'm just following the guide. I assume you mean I should increase vcore and fsb more than the guide says and not increase the others.
thanks
