check the psu if u suspect its that:
1. check for sparks when u turn it on (the clicking)
2. check the wires in your case it may be in contact witht he fans to make the click sound
so you were able to get into the bios, what happens after that? if you can boot all the way to bios then i am pretty sure your psu is not dead.
