the system that i am eventually going to be WCing is 1 cpu (e6700), northbridge, and 2 8800 GTXs, all of this with 1/2 tubing preferably
i have been told that the Laing Pump is a great pump but i just wanted to double check that it would be able to hand this set up
also does anyone know if the size of the reservoir actually matters?? because i have seen some tiny ones like Swiftech Micro and huge ones like the Danger Den Dual 5.25 Bay Reservoir and personally i think the tiny would be much nicer as long as there was not some major down side to having it
