Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > I think my cable modem is dying, help!!!
Forum General Networking : General Gateways, Routers and Firewalls - I think my cable modem is dying, help!!!
my modem will be going on 5 years now and I think it's showing its age. For almost a week or so, it would just drop connection. Sometimes, it will just flash send and recieve will stay lit and other times, it will just flash "recieve". I unpluging and repluging helps but not often. I've tried: disabling my firewall and torrent clients, repairing my connection, enabling/disabling my connection, and slapping my modem a few times. I am at my wits end about to call my supplier's tech support with a very angry request or a new modem. Anybody have any ideas on what my problem can be? Thanks in advance.
Sponsored Links
Try bypassing the router if you have one. Use a different Network interface card or borrow another computer.
If not it could be the modem as you say.
Reply to evongugg
- 0 +
If your modem is from your ISP, they're not likely to give you a hard time about replacing it. Usually you can just take your old modem into their store or physical location and exchange it. At least Time Warner has never given me a hard time.
Reply to g-paw
When the modem flashes "Send", it means it cannot get its RF signal back to the cable company. This could be caused by a high reverse signal (too many splitters), or another signal leaking into your cable line somewhere and causing interference. And usually if it flashes Send for too long, it gives up and goes back to the receive light.
It also can be caused by a bad modem.
Ya, so you can swap out for another modem (if yours is from the cable company). And if that doesn't solve it, then you'd have to call them and probably get a tech out there to check your signal.
------------------------------ 5000+ AM2 @ 3.0GHz | MSI K9A Platinum | HIS x1900xt 256MB | 2 X 1GB OCZ Platinum Rev. 2 DDR2-800 | 2 X 74GB Raptors RAID 0 + Barracuda 120GB | 600W MSI Turbostream | Antec NineHundred | Zalman CNPS-9500 AM2 | Logitech G15 & G7 Laser | 20" Acer AL2016W
Reply to enPhotic
There are 1165 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
