Adobe flash player 10.1 problems
Hello,i got some issues with 10.1 i clean install two days ago but it's not working properly, i try to reinstall meny times and still no go, again and again... i know i'm not the only one,but can someone tell me if there is a fix ??
http://img94.imageshack.us/img94/4596/adober.png
Thank you !
10 answers Last reply
More about adobe flash player problems
  1. WOW..thanks
  2. Hey ortoklaz,
    I just came across your thread. I'm at work right now, and the image is blocked, but I'll check it out when I get home in a few hours.
  3. Here's a troubleshooting checklist.
    http://kb2.adobe.com/cps/191/tn_19166.html
    Also, you can look for an error log at one of the following locations:
    * C:\WINDOWS\system32\Macromed\Flash folder for a 32-bit machine
    * C:\WINDOWS\SysWOW64\Macromed\Flash folder for a 64-bit machine
  4. See.. the think is that i allready(clean) instal adobe flash twice 10.1,but there is some kind of " bug",a lot of people reporting it and i don't know if there is a fix .
    10.1 work most of the time but like you said.. " right now, and the image is blocked, but "..perfect exe.
    http://img153.imageshack.us/img153/3680/adobed.jpg
    see the image is overlapping
    now steam;
    http://img811.imageshack.us/img811/9302/steamy.jpg
    Uploaded with ImageShack.us
    adobe forum;
    http://forums.adobe.com/message/2980485?tstart=0
  5. Try it with a different browser. Are you using chrome?
  6. explorer works but chrome..suck
  7. FF might be worth a shot. It has a flash plug in for the browser.
  8. I'm just going to stick with good old IE for now and wait for a fix,thank you for your help aford 10, i appreciate it
  9. Ok. Sorry I didn't have a better one for ya!
    btw, did you right click and run it as administrator? (shown in #4 of the link above)
  10. Welcome to adobe flash, the most hated app apparently.
Internet Applications Flash Player Clean Install Adobe Apps
