Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » Can Somone Help Me With A Strange Problem, Thanks!
Add a reply
 Word :   Username :
 Page :   1  2  3
Previous
Author
 Thread : Can Somone Help Me With A Strange Problem, Thanks!
Profile: stranger
More Information
ok hi
i had a athlon 3500 plus cpu 2.2 gig
3 gig ram
geforce 8600gt 256mb
550 wat psu
mobo temp was 29
cpu was 35
video card was 44
now
all ive done is put in a geforce 8800gts (NOT OVERCLOCKED)320 meg(huge card)lol
ive also fitted athlon x2 4 gig 3600 plus yesterday and this has happened.
MY VID CARD READS 70 IDLE!!!
MOBO IS 48
CPU IS 46
AND MY FEET ARE VERY WARM!!!!
ITS QUITE HOT IN MY ROOM AND WARM AIR DUE TO THE SUN HEAT NOW.BUT ANYONE NO WATS GOIN ON?
I HAVE A CASE FAN AT REAR,AT FRONT AND AT SIDE HITTING THE MOBO AND VID CARD.
WHY THE CHANGE IN TEMPS? AND IS IT OK?I NO THESE VID CARDS HAVE A LOT OF HEAT BUT WHY DOES THAT CHANGE THE MOBO AND CPU HEAT?
CAN THE PSU BE CAUSING IT?I NEED 450 WAT AND 25 AMPS ON 12V.IVE GOT 550 WATS AND 24 AMPS ON 12V.
THANKS
Related Pr oduct
Profile: newbie
More Information
If the weather has gotten warmer, this will increase the ambient temps in the room, thus increase the component temps in the case.
Quote :
The heat generated by the bigger card is gonna make the temps in the case higher and the hsf will be blowing hotter air over the processor... ergo warmer mobo and cpu. You've also gone with a faster dual core cpu... this will also raise the temps.
Profile: old hand
More Information
Well, both of your new components will put out more heat than the old ones, so it's not really a surprise, but the temps are high.
Also you say it's hot in the room - so naturally the PC will be hotter as any heat it pumps out will be on top of the ambient temperature. In that case, probably the best advice is to get some dark curtains!
If you take the side off of the case I guess the temps go down?
Profile: stranger
More Information
OK BUT IS THIS OK TEMP WISE?
MY CARD MUST GOTO ABOUT 90 I SUPOSE WEN PLAYIN GAMES.
IVE HAD NO LOCKUPS AT ALL YET OR PROBLEMS PLAYING GRAW AND BIG GAMES.
IF I PUT MY HAND NEAR THE CASE ALL YOU CAN FEEL IS HOT AIR COMING OUT NOT COOL.
I CANT REALLY DO ANYTHING ELSE TO COOL IT.IVE ENUF RUNNING AS IT IS.
AS LONG AS THE PSU CANT CAUSE IT TO DO THIS COS ITS MAYBE 4 OR SO AMPS SHORT?
Profile: stranger
More Information
BASICALLY WEN I TURN THE MACHINE ON THE CARD READS 48 DEGREES.IF YOU WATCH THE NVIDIA MONITOR IT GOES SLOWLY UP TO 72 OR SO AND DOES IT IN ABOUT 10 MINUTES.
IVE ONLY HAD THE 2 IN THERE FOR 24 HOURS.THATS WEN I FITTED THEM.I HAVE HEARD OF 8800 S BEING 70 AT IDLE FROM OTHER GUYS BEFORE ON SITES.
Profile: newbie
More Information
I guess the temps are a bit hot for an Athlon maybe?? As for the card, there was a thread here recently where folks were talking about high 90s, even 100+!!
Quote :
At least the case is getting rid of the warm air. I've never had cool air coming out of a case exhaust fan.
Profile: enthusiast
More Information
Completely normal. My 8800 idles upper 60's but I manually adust the fan to 80% and this drops the temps into the 50's at idle, also helps keep the case temp down. The highest fan I have seen on auto is about 68% while gaming and the card was blazing so the manual setting works just fine.
Profile: addict
More Information
i walked away from the computer for a while and forogot to hit submit. others already said exactly what i posted. lol
Profile: stranger
More Information
LISTEN
IVE USED RIVATUNER TO PUT THE FAN ON 100 PERCENT ON STARTUP AND THE GPU HAS COME DOWN TO 61 AND MOBO 35 AND CPU 40 AND THE TEMPS ARE STILL DROPPING!!!!IM WATCHIN IT NOW.WHOEVER SAID ABOUT SPEEDIN UP THE FAN CHEERS.SEEMS TO B WORKING.IS IT OK TO HAVE THE FAN ON 100 PERCENT ON RIVATUNER OR NOT?
Profile: nimble knuckle
More Information
http://www.jacobfoshee.com/wages/caps_lock.jpg
Profile: stranger
More Information
thanks everyone for ure help.
AND SEAL BOY HAVE YOU NOTHING BETTER TO DO?
DO U WAIT  AND PREY ON GUYS USING CAPS?U SAD SAD PATHETIC MAN.
HERE JUST FOR YOU SEAL.http://www.myspacecomedy.com/images/funny/kid-middle-finger.jpg
BYE ALL
A+, Net+, Forum+. life+
Profile: Eternal Poster
More Information
Dumb cluck slimpunk... burn in tech hell.
CAPS ARE FKN ANNOYING so STFU.
More Information
Quote :
BYE ALL
Yeah, I'm the dreaded CAPS LOCK STALKER!!!!111!
Idiot.
Profile: stranger
More Information
U COUPLE OF RETARDS.
ILL WRITE IN WATEVER MEANS I CHOOSE DIKHEADS.
LAUGHS WHAT A COUPLE OF TRANNIES.
GET A LIFE YOU PATHETIC CHOCOLATE CHANNEL CHASERS.(GAYBOYS)
I HAVE THE LAST WORD HERE THIS IS MY POST.
AND IM OUTER HERE NEVER TO RETURN.
HERES THE LAST WORDS.
RETARDS
Profile: addict
More Information
Quote :
BYE ALL
Idiot.
lol xD
Profile: journeyman
More Information
Quote :
I AM A RETARD
Highly doubtful... trolls always return to see what they have stirred up.
Also, I recommend you get this shirt... it suits you well.
http://img118.imageshack.us/img118/7364/capslocklj4.jpg
More Information
Quote :
RETARDS
Was I just called a... "CHOCOLATE CHANNEL CHASER"? You gotta be kidding me...
Profile: old hand
More Information
lol - do you get picked on at school?
Profile: addict
More Information
Hehe, pretty clevor dis actually. But he's still reported. Viva la Caps Stalker!!!!! :trophy:
Profile: stranger
More Information
If you're coming in to a forum asking for help, it is in your best interest to use a language people understand.  Typing in all caps, not using any punctuation, and a liberal use of "U" generally means you won't get any help, because it's just not worth most people's time to attempt to read.  Sorry to break it to ya, but punctuation isn't something that was invented to torment small children, it DOES serve a purpose!
Profile: stranger
More Information
AGAIN FOR THE LAST TIME
THANKS VERY MUCH THE GUYS THAT HELPED ME YOUVE FIXED MY PROBLEM.
EVEN THOUGH I USED CAPS!!!!!
FOR THE PLANKS THAT SEEM TO WANT NOTHING MORE THAN AN ARGUMENT AND PROBABLY LIVE WITH THERE MOTHERS AT 40 STALKING THERE NEIGHBOURS PANTIES ON THE LINE NEXT DOOR GOTO HELL.
More Information
