I got the part in for a homebuild im making for a friend. After I got it all put together and plugged in, I pressed the power button, lights lit and fans spun for about 1 second, and then it powered back down
I checked and rechecked everything, it's all plugged in correctly. I am thinking it might be a bad motherboard, but this is my first intel build and i dont have any other boards i can swap out to test it.
Asus P5N-E Sli
Intel Core 2 Duo E6600 2.4
2gb G.Skill DDR2 800
Seagate 320gb 7200 RPM Sata 3.0
BFG GeForce 8800 GTS 320mb
Samsung 18x DVD+RW
am i forgetting to do something important that i can laugh at myself about later? (hopefully :? )
thanks for the help
Asus P5N-E Sli
Samsung 18x DVD+RW
thanks for the help
