Problems setting Up Network
Forum General Networking : Network General Discussions - Problems setting Up Network
I have my main computer and two other computers that hook up to the internet through a netgear WPN311 wireless router. I just built a new computer and for some reason I can't get my network set up. I had so many problems I even reformatted again hoping it would help, but it didn't. When I set up the network it installed an internet gateway in my network setting, and when I try to run the network wizard it says it can't complete wizard. I need to get rid of the internet gateway, and start from scratch, but I don't know how.
Sponsored Links
Every time I run the network wizard it gives me a cannot complete wizard message. I've had wireless networking for years, and this is the first time I've had this many problems. On top of all this it tries to enable the windows firewall everytime I run the wizard, which I don't recall happening in the past.
Reply to buffdaddy110
- 0 +
Are you fully updated via a wire instead of wireless?
What's the exact error you get? Device is installed with correct driver?
------------------------------ "Alcoholism is a disease, but it's the only one you can get yelled at for having. Goddammit Otto, you are an alcoholic. Goddammit Otto, you have Lupus... one of those two doesn't sound right." M. H.
Reply to Riser
I reset my router hoping it would remove it from network connections as a residential gateway. Luckily this reset everything back to normal, and I was finally able to get the network up and running again.
Tom's Hardware > Forum > General Networking > Network General Discussions > Problems setting Up Network
There are 1111 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
