I received a Windows Update nag for a .NET1.1 Security Fix which could not complete. On the web, I read that I needed to uninstall .NET1.1 re-install it using a MS-Tool that changes all the references.
I did that (PS and had to re-install half a dozen previously working programs) and indeed .NET1.1 could be re-installed which fixed the issue with Window Update.
A few moments later I received the same type of Update nag again, this time for an Update to .NET3.5. I tried to uninstall .NET3.5 using the Add/Remove Programs and it appeared to uninstall. Now I cannot uninstall .NET3.5 or install it either. It does not show in Add/Remove Programs, but the .NET3.5 installer claims that it is already installed.
What should I do?
Message edited by Cswa on 10-19-2009 at 05:38:41 PM
This is a reply to myself, because I managed to fix the problem, by the mercy of those on the web who had the same problem and posted their experience online and Aaron Stebner who wrote the application which removes all traces of particular .NET Installations.
Then I ran the tool selecting only the .NET3.5 Installation (.NET1.1 was fine). The Tool did its magic, and when I ran the downloaded MS .NET3.5 Installation exe, this time there was no remnant of the .NET3.5 Installation to goof the fresh Install. Once this was done, then Windows Update was happy and stopped claiming that some Updates were not Installed.
If anyone out there has the same problem, check this out.
