Tom's Hardware > Forum > Windows Vista > Vista General Discussion > [Solved] Prepairing your desktop problem, can't log on
Forum Windows Vista : Vista General Discussion - [Solved] Prepairing your desktop problem, can't log on
Best answer from fowang.
I made a fresh install of vista for a upgrade to windows 7, I trasfered all my files vista and it worked perfictly fine. but some how, soon after I noticed everytime I log on, it says preparing your desktop, as if an account was newly created or it couldn't accses ur user profile, it ends up making a temp directory, but after quite a couple minutes It just goes blue and I see my mouse, I am unable to do anything but I can press Ctrl+Alt+Delete and get to task manager and their for create a new task which is comand prompt and use that, I even tried using it to activate the hidden admin account and it dose the same blue screen, and the same happens for all accounts. what can I do to fix it, from
my understanding it's that the OS no longer remembers where the profiles folders are.
By any chance, when you say you tranferred your files over did you trasfer the user profile from vista straight into windows 7?
Also when installing windows 7 did you use the custom install or the upgrade option?
Sponsored Links
sounds like it...
try repairing from the disk...
or just reinstalling again since this is a fresh install anyway
Reply to arges86
Best answer
------------------------------ Intel core 2 duo e6750 @ 3.3ghz
Asus P5N32-E PLUS SLi nForce
4gb ocz pc 9200
6 satas
Reply to fowang
*** ed so i reinstalled vista so i could upgrade it to win7 for less, then after creating accounts on the new vista with he same names as the ones on the old vistas deleted the old vista partition, it was working perfectly, i was able to accees the files, and i think its CHKDSK with all 5 steps that i noticed it was not working, not sure it it was right away or not though
Reply to win7man
There are 525 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
