Hello, hello, i have problem I have image to install it via symantec ghost and ris but symantec ghost corporation v8.3 refuse install image size more than 3300 MB
answer
Last reply
More aboutsymantec ghost problems
hang-the-9
What program did you use to take the image? If something will capture the image, it should restore it.
Did you check with Symantec about this file limit or is it just something that's happening?
