My system:
CPU - Intel(R) Pentium(R) D 3.20GHz
MOBO - Intel Corporation DG965RY
RAM - 2X 1GB KINGSTON SDRAM 1GB/64 @ 667Mt/s
VIDEO - Radeon X1300 Series
OS - XP/2002 Home SR2
AUDIO - 6-channel (5.1) audio subsystem using the SigmaTel* STAC9227 audio codec
HD-1 - WD 180G Sata drive
HD-2 - Seagate 320G Sata drive
My new system has been troubled in the sound dept since built. I started out with another Intel board, D946GZIS. Put 2 of those in but neither could run the microphone either through the front or rear connections. Just switched to the DG965RY, same problem, sometimes mic works but too low to be heard, sometimes doesn't register sound at all. This seems to be a well known problem with these boards. All use the same Sigmatel system. Sounds play without problem, just can't record through mic or use Skype.
My bios and drivers are up to date. On the earlier boards, I tested the mic on a drive that had Win XP and nothing else, and still had mic failure, so I don't think the problem is a corrupted registry, but I could be wrong somehow.
Called Intel help and they say because my OS was set up first with the DG946GZIS I must format primary drive and reinstall XP to run new board without problem, they say the new board is somehow looking for the old board drivers, hence my continued mic problem. Is this true?
The shop that built my PC says not necessary, that Intel always makes you format just to rule out Win issues. Shop suggests we put in a decent sound card and disable the onboard sound. Plan B is to switch in a different MOBO that does not use Sigmatel.
Any advice much appreciated. I want to avoid a format and reinstall if I can as I always seem to lose something, mostly time and patience.
Thanks for letting me ramble.
Belson
Belson
