Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » Motherboard ATX power connection problem? new mobo no go?
Word :   Username :
Bottom
Author
 Thread : Motherboard ATX power connection problem? new mobo no go?
Profile: addict
More Information
Installed a new MB, heatsink.
I noticed that mobo takes a bigger ATX power connector that my psu has. MB has 24pins my psu has 20.
I did get it to start, and it started to boot before I could enter bios so I turned it off.
Now I wont even get a beep, video dont come etc. Fans spin though..
I have cleared cmos. Removed everything except video and memory. Have tried with just video and no memory.
Gonna take it out of the case and put it on a box next, but lets assume that dont work.
Any clues ?
Thanks
Related Product
Profile: Ancient Poster
More Information
You can use a 20pin connector with a 24pin mobo, but you should probably use an adapter. They're pretty cheap, and you can get 'em on Newegg, FrozenCPU, Performance-PCs, ect.
If nothing is turning on the psu is probably at fault. Hook a few case fans up to it and short a green and black wire on the 20pin connector.
Like this:
http://www.dansdata.com/images/digidoc/runatx360.jpg
If the psu doesnt turn on it's most likely dead.
Profile: addict
More Information
I am getting case fans to spin.
Just no beep. I can get the connector in, just doesnt go in all the slots
Profile: addict
More Information
UPDATE.
Ok, its all working now.
I took it out of the case and on a cardboard box, taking everything off, redid the cpu and heat sink, got it to boot once, but then it wouldnt.
Took every off again, redid the cpu heatsink, tested and got a beep. I then added one thing at a time, each time testing for a post beep. This was my process
1. clean cpu, resinstall add thermal paste.
2. Put on heatsink and attach fan but dont screw on and test with hand pressure. Got a beep
3. attach heatsink and fan, beep
4. One stick of memory, beep
5 2nd stick of memroy, beep
6. video card, beep
7, hard drive, beep
8. Add various case fans (mostly just to make sure it wasnt the psu crapping) beep
9 DVD/cd RW, beep
10. Floppy. beep
Take it all off again except heatsink and memory, install into case with out screwing it in. got my beep, screwed it in, got my beep.
And then I repeated the above process from 6 down.
Now we are all good, after many hours of fiddling.
Thanks all
Google Ads
News
MSI launches SLI mobo for Intel P4 platform
Published on July 19, 2005
Micro-Star International (MSI) announced on July 15 the availability of the P4N SLI motherboard for the Intel LGA-775 Pentium 4 CPUs, with a price tag of NT$9,500 (US$298). Read more
AOpen to introduce Pentium M mobo using desktop 915G chipset
Published on May 17, 2005
AOpen is set to release its i915GA-HFS motherboard, which although based on Intel's 915G desktop chipset, will support Pentium M CPUs, according to sources at the company. Read more
Intel claims no tight chipset supply, mobo makers not so sure
Published on May 26, 2005
Ever since late 2004, the shadow of an Intel chipset shortage has hovered over the motherboard industry. Read more
Second-tier mobo makers 1Q shipments down on-year
Published on April 08, 2005
Among four second-tier motherboard makers, including Biostar Microtech International, Diamond Flower Electric Instrument (DFI), Epox Computer and Jetway Information, only Biostar saw an on-year increase in its motherboard shipments in the first quarter of this year, and even that growth stood at only 0.4%. Read more
Latest Reviews & Articles
Seagate's 1.5TB Barracuda: Bigger And Better?
Published on October 02, 2008
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky - Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
