Tom's Hardware > Forum > Windows Vista > Configuration & Customize > Hard disk shrink problem
Forum Windows Vista : Configuration & Customize - Hard disk shrink problem
Hi, I purchased a DELL Studio 1557 LAPTOP with Windows Vista Home Premium 64 bit pre-installed.DDR3 4GB Ram. And 500GB Sata hdd. The basic partition given is "C" i.e. Windows drive. I want to partition it to 50,50,300 gbs respectively. but I was only able to shrink 239.58 GB as un allocated space. and rest 211 gb on the c drive is not being able to shrink and its showing a message " Size of available shrink space is restricted is snapshots or pagefiels are enabled on this volume."
I removed the pagefile on C and tried, but no use. Is there any solution to partition the rest of the space on C. I also tried paragon partition manager,that still caused more problems.
Regards,
A.R.
Sponsored Links
What about the other 100gb? but anyway try partition magic
------------------------------ Intel core 2 duo e6750 @ 3.3ghz
Asus P5N32-E PLUS SLi nForce
4gb ocz pc 9200
6 satas
Reply to fowang
try to turn down the amount of space that system restore can use.
I think It may be trying to preserve that space.
You may also possibly have to trun it off in order to do this and then turn it back on.
Message edited by pat mcgroin on 10-30-2009 at 03:23:25 PM
Reply to pat mcgroin
yes. I turned off the system restore and also disabled the volume shadowing service.but still couldn't find the apt solution.
Reply to ebhendra
There are 753 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
