Tom's Hardware > Forum > Windows XP > Device Driver > USB port problem
Since installation of SP3 for XP, all USB ports are inactive and don't show up in My Computer at turn-on. I have to reboot two, three and occasionally four times before they activate and detect anything. Any ideas?
Sponsored Links
Check the device manager to see if there are any conflicts. If not, uninstall all the usb root hubs and restart. They will reinstall upon restart.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
I tried your suggestion but to no avail. Got any other ideas?
Reply to sturonron
- 1 +
You can try restoring back before the SP3 update to see if the problem goes away. If it does, you know the cause. If it's not the problem, you can always re-download the SP.
Reply to aford10
There are 1195 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
