Tom's Hardware > Forum > Windows Vista > Vista General Discussion > Problem: cpu is always working 60 - 80 %
Forum Windows Vista : Vista General Discussion - Problem: cpu is always working 60 - 80 %
Hello everybody
As I know whin you are not doing any thing with the computer .. the cpu should only be using 1-5 %
but I noticed in my computer that it's using up to 60-80%
and with small thing working it's 100%
my computer is slow now .. so what should I do .. ?? and how can I know where's the problem
thanx
Sponsored Links
Open the management console (Ctrl/Alt/Delete)
Choose 'Show All Processes'
Sort by CPU, and you will be able to see what is using the msot processor cycles.
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
You must loard too much application, them take up your CPU useage. It seens your computer runs slow, you should clean your registry.
Reply to xxnideoo
- 0 +
You didn't say what kind of cpu you had. I had Vista with a 1.6 GHz cpu and from the event logs, my virus scanner was a problem and Windows Explorer as well. Also if you did an upgrade there may be a lot of files left on your system which can cause a problem. You have to be careful about their removal though and I'm still looking for straight answers about a lot of them. Also as someone mentioned in Vista you can check what is running when you start-up and if you don't need it as soon as you turn on your pc then disable it. Just start it when you need it.
Reply to 1oldie
There are 1143 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
