Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Help - What to do to keep the 'firewall' setting 'On' ?
Forum Windows XP : Windows XP General Discussion - Help - What to do to keep the 'firewall' setting 'On' ?
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I use a Laptop with XP Pro and have loaded the SP2 updates.
For some reason, any time I do check for the 'firewall' settings -
using 'Start', 'Network Connections', and check the 'Properties'
of the 'Ethernet Adapter', and under 'Advanced', I see the
'Windows Firewall' setting turned 'Off'. I do change the setting
to 'On'. Almost every time I boot the Laptop, the setting changes
from 'On' to 'Off'.
Question - any idea why does this setting automatically changes
from 'On' to 'Off' ? Any comments will be highly appreciated.
O Noah
P.S. I do have 'Zone Alarm', 'Norton AntiVirus', 'AVG AntiVirus',
and 'Microsoft AntiSpyware' running. I also run Ad-Aware once a
week to keep the Laptop clean.
Sponsored Links
If you turn Zone Alarm off, the Windows firewall should stay enabled. You don't need
a belt and suspenders.
Mary Sauer MSFT MVP
http://office.microsoft.com/
http://msauer.mvps.org/
news://msnews.microsoft.com
"O Noah" <o_noah@hotmail.com> wrote in message
news:OrKvHjkaFHA.4040@TK2MSFTNGP14.phx.gbl...
> from 'On' to 'Off'.
> O Noah
Reply to Anonymous
Good way to put it!
Unless you're trying to keep yourself from getting online, why on earth
would you want two firewalls running?
> Mary Sauer MSFT MVP
> > from 'On' to 'Off'.
> > O Noah
Reply to kelly
That shows technically how deficient I am.
Thank you so much for educating me.
O Noah
"Mary Sauer" <gsauer@mycolumbus.rr.com> wrote in message news:eWveySoaFHA.1456@TK2MSFTNGP15.phx.gbl...
| Mary Sauer MSFT MVP
| > from 'On' to 'Off'.
| > O Noah
Reply to Anonymous
In fact, I was having trouble to keep my Laptop active, since
I had two firewalls running. Thank you for educating me.
O Noah
"Kelly" <Kelly@discussions.microsoft.com> wrote in message news:1BAD3971-7B59-4BA5-9F7C-832E799A55D4@microsoft.com...
| Good way to put it!
| > Mary Sauer MSFT MVP
| > > from 'On' to 'Off'.
| > > O Noah
Reply to Anonymous
I used to run Zone Alarm but because of various problems with new programmes
I have discontinued to use it. Are you saying that with Windows Firewall
active there is no other advantage in running Zone Alarm?
I am interested in the answer as I often wonder if I should activate Zone
Alarm again?
Blair
don't need
> Mary Sauer MSFT MVP
> > from 'On' to 'Off'.
> > O Noah
Reply to Blair
> Alarm again?
XP Firewall checks incoming traffic only.
Zone Alarm and most other third party personal firewalls check incoming and
outgoing. Having outgoing traffic monitored may give you an early tip off
that the system has acquired a trojan, worm or other malware - one that is
not yet detected and cleaned by the installed and active antivirus program
or anti-spyware program.
Sharon F
MS-MVP ~ Windows Shell/User
Reply to Anonymous
There are 869 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
