Hi everyone
Ok so I just got a newer build. My old system had been with me for 3+ years and it was time to get something else.
I got the abit IP35 Pro and I am liking it very much. With the exception of one thing. I was unable to set up a RAID 0 to install windows into. I have used raid0 and I am a bit of a fan of it.
I have set up raid 0 machines in the past so I am not exactly new at it.
This is what's happening now.
In the bios I changed the sata controller to raid. Then in the post screen I build a raid 0 array with my 2 hard drives. Thereafter I reboot with the Windows cd in the drive. Upon entering the windows installation I hit F6 to add addition drivers. (This motherboard's CD does come with the option of building a driver disk for the new ICH9R chip). After asked to add additional devices by pressing S I think I put the floppy in and I am asked to select the type. I chose the Intel raid something or other 32bit because I am installed 32bit XP. At this time the system reads the floppy and everything is fine. Then it asks for additional devices. I say no. (All of this is the same as with all other machines I have played with so far) At this point the installation continues as normal. I am then given the choice of wher to install windows. My raid) array is the only option as that's all I have. I choose it and format it no problems there. Thereafter files start to be copied into the HDs and about half way through that process the System comes up with an error saying something like "unable to copy iastor.ini" or .inf or something anyway this is the same file I originally copied over after pressing F6. Now, no matter what I can't get past that error. I have tried multiple floppys with no luck. if I skip it then installation will crash once windows attempts to boot.
Not sure what the problem is or if anyone has a work around. Any input would be appreciated.
Thanks.
Thanks.
