Tom's Hardware > Forum > Windows XP > Configuration & Customize > Best way for XP to power itself down
I like to run system maintenance at the end of each day, but want the computer to completely power down afterwards. Is Hibernate the best way to accomplish this?
Thanks.
Sponsored Links
I believe when you schedule tasks, you can set it to shutdown after completion.
Hibernate is just a low power sleep mode. It doesn't power down, it just uses less power.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
Wrong! Hibernate saves the state of the computer to hiberfil.sys and POWERS OFF the system. Stand By Mode is low power.
Grumpy
Reply to Grumpy9117
- 0 +
Wow, relax grumpy.
Yep, I was incorrect in my previous statement. It does power down. It stores your RAM contents so when you come back it starts up where you left off.
Reply to aford10
There are 772 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
