I posted over on the AMD forums and they provided absolutely no help. I've received help from here a few years ago and stumbled across the site while trying to fix my problems.
I built this computer about a week ago and have been continuing to run into CPU heat issues.
I'm using an ASUS M2N4-SLI board, 2GB of Corsair RAM with an AMD 5600+ and an NVIDIA EN7900GS. I'm running Vista Ultimate on a 250GB HDD and to monitor my temps and voltage, I've been using PC Probe II provided from ASUS's site (the latest update they have released).
Initially, using the stock HSF provided from AMD I was receiving temperatures around 50-55C idle and under heavy load 67-71C! So I picked up a Zalman 7900 Heatsink and Fan. I did use Arctic Silver 5 on the install of the Zalman. This lowered my overall temps quite a bit, but I'm wondering, is this still running too hot? It's now averaging 42-46C idle/50-55C under load... although sometimes upon idle it will spike to approx 48C?!
I'm new to Dual Cores and I've seen so many different "recommendations" that I don't really know what to think here. Is this an average operating temperature?? I really don't think air flow is the problem, it's quite open for a mid-tower. I would be happy to post pics/more information if necessary.
Thanks for your time and help guys!
EDIT: Forgot to add, PC Probe is recording an average of 33-34C motherboard temp. While I'm at it, here are two pics of the computer...
EDIT x2: I forgot that I didn't have the air conditioner on in my room. Regardless, I turned it on and idle temp is holding steady at 40-42C.
