Problems
Forum Windows Vista : Configuration & Customize - Problems
I my D drive will not install or play any disk programs have i not got the settings correct? :hello:
Sponsored Links
Is the D drive a DVD drive or hard drive?
Is it a new install, or a working drive that just started doing this?
Does it show in my computer? Disk management?
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
^How he said, It seems as if D were a DVD or CD drive.
P.D. You don't need post the problem 3 times.
------------------------------ If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
Ya, that's what I was thinking, but it's not real clear. And it makes a big difference on what to diagnose.
Ya, agreed. Newbie trying to score extra points :lol:
Reply to aford10
IIt is a DVD drive, I am a newbie & did i not intend to post 3 times but your software kept telling me I was't registered
Reply to alsmith39
It as only started doing this recently it is a cd grive but will not install new programs
Reply to alsmith39
The CD drive don't read anything? music, games, programs, files....or just the autorun don't works.
Reply to saint19
I think it could be the autorun but I'm not sure, all the autorun boxes were set to default
Reply to alsmith39
The D Drive is only the CD drive :D
Reply to alsmith39
Autorun isn't a big deal. Put in the cd, go to my computer, and double click on your D drive.
If it kind of freezes or shows an empty disc, the problem is likely the disc. If the drive isn't showing up, then it's the drive/software.
Reply to aford10
^+1 or try with a external cd/dvd drive. If the external works, the problem is your cd drive.
Reply to saint19
Nothing happens when I click 'my computer' except video TS appears as a blue box, the disc loads on my XP3 laptop
Reply to alsmith39
That means you're trying to play a video CD. Download VLC, right click on the drive, choose to play with VLC. Or open VLC and under the file menu, you can open the video CD.
http://www.videolan.org/vlc/
Reply to aford10
I've tried VCL, the same thing, but I am trying to install Printmaster from a cd program i don't understand why autorun will not open it . It installs on XP3
Reply to alsmith39
Yes, the same thing will happen. If you are in VLC, you need to select on that video_ts folder and play that file.
To set up an autorun default, right click and go to the properties of the CD drive in my computer. On the autoplay tab, you can set default actions for each type of media.
Reply to aford10
Tom's Hardware > Forum > Windows Vista > Configuration & Customize > Problems
There are 797 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 caljomac won the Freshman badge
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
