Tom's Hardware > Forum > Smartphones & PDAs > Handhelds General > solar power for ipaq 2210
Forum Smartphones & PDAs : Handhelds General - solar power for ipaq 2210
Archived from groups: comp.sys.handhelds (More info?)
Hello
I am looking for a solar panel to recharge or possibly run an
ipaq 2210/2215. I got my eye on this one
http://www.icpsolar.com/ssfamille.php3?id_rubrique=14
The problem I am having is fiquring out the volts, watts and amp.
The charger that came with the pda says the output is 5volts but most
pv units are 6volts and up. Will this harm my pda?
The charger output is also 2 amps (2000 milli amps???) so would
charging the pda at a much lower amperage 290 for example harm the
pda?
Or it as simple as finding a pv panel that has the right wattage? In
my case 10 watts.
Thanks a bunch for any help you folks can give.
Sponsored Links
johnson.. <merifreekinxmas@yahoo.ca> wrote:
> Hello
Possibly.
> pda?
Possibly.
> my case 10 watts.
Volts is analogous to pressure, amps to flow.
The maximum flow of electrons from a solar cell depends on how much it's
illuminated, and how much the rest of the circuit constricts that flow
(resistance).
The maximum voltage depends on the design of the cells (typically 0.6V
for each solar cell).
Like pipes, circuits can be damaged by high pressure/voltage.
Like water, the more flow (current) you have, for a given source, the
lower the pressure (voltage) you get.
The other problem is that a "2A" solar cell will often produce far less
current than that, due to poor weather, ...
More description of what you want to do with it would be handy.
Reply to Anonymous
"Ian Stirling" <root@mauve.demon.co.uk> wrote in message
news:4103d5cb$0$44458$ed2619ec@ptn-nntp-reader02.plus.net...
> > Hello
> Possibly.
> > pda?
> Possibly.
> > my case 10 watts.
> (resistance).
Hi Ian
Basically I'm gonna go camping and want to charge the battery of the pda
while doing stuff in the day and use the pda at night while laying in bed. I
will be travelling by bicycle and most likely not have access to ac outlets,
car cig lighters etc.
thanks
Reply to Anonymous
>> > Hello
>> Possibly.
>> > pda?
>> Possibly.
>> > my case 10 watts.
>> (resistance).
> Hi Ian
Ok...
How long will you be away from AC?
The battery in most PDAs is typically around 3.6V, 1300mAh, and store
some 4.6Wh.
A 12V 3.2Ah lead-acid battery will weigh around a kilo, and store enough
energy for some 7 charges, or perhaps a week or so if you run the PDA
battery down every night.
4 alkaline D cells will store enough energy to charge it about 25 times, and
weigh around 600g, and cost rather little.
Alternatively, to get enough power to charge the battery (4.6Wh), over
say 8 hours of riding, you need about half a watt.
In practice, this is probably a 5W power solar panel.
However, unfortunately, the solar panel won't quite match the requirements
of the power input of hte Ipaq.
Do you have a bicicle lamp/generator?
How do you keep those charged?
Reply to Anonymous
Good day,
Yes, using a higher voltage can possibly damage your PDA.
If you know anything about electronics using a Zener diode that limits
the voltage to 5 V would be a good idea to ensure that the voltage is
never too high.
As for getting a solar panel with 10W output (at 5 V), you probably
wouldn't be able to travel on a bicycle with it (or at least not packing
too many other things!)
As for using a low ampere source, it may not be able to charge your
device. It is unlikely that your PDA actually draws 2 amps while
charging but it would almost certainly be more than 290 mA. If your
charger cannot supply sufficient current, then you will get a voltage
drop and almost certainly it will not charge the battery (since most
modern electronic devices will detect the input voltage and switch off
anything not within a certain range).
Regards,
Michael Tam
Reply to Anonymous
There are 1124 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
