Tom's Hardware Forums » Wireless Networking » Setup, Configuration & Security » HELP PLZ! i need help configuring my netgear wn802t wireless access po
Add a reply
 Word :   Username :
Bottom
Author
 Thread : HELP PLZ! i need help configuring my netgear wn802t wireless access po
Profile: newbie
More Information
I just bought the netgear wn802 wireless access point to hook up to my wireless router (linksys 802.11b).
I am totaly lost i have no idea what to do. it says for the first steps to configure the computer with a static ip address of 192.168.0.210 and subnet mask 255.255.255.0?? what does that mean do i have to change something? and what does static mean?
step c it says connect an ethernet cable from the wn802t to the pc and it says before that prepare a computer with internet access and an etherenet adapter. If i connect the wn802t to the pc i have to take my router ethernet port out then i won't have any internet access
please help on what settings i have to change and what i need to do
Any replies are appcreciated=DDD
thankssssssss
Related Pr oduct
Profile: newbie
More Information
also like it says that when you conect it to the computer all light should light up but only the power light lites up
Profile: Faithful Poster
More Information
All you have to do is run the setup CD before you plug in the access point. Plug it in when it tells you to. It will let you search for wireless networks when done. Click your network and hit connect. Its that simple.
Profile: newbie
More Information
there is no instalation cd all there is , is a cd that has a pdf format instruction manual on it
Profile: newbie
More Information
do i need to have 2 eithernet ports or an ethenet adapter or something i have no idea i'm really lost someone helpp pleasee
Profile: old hand
More Information
Why do you need a wireless access point if you already have a wireless router?
Grumpy
Profile: member
More Information
This will take such a long explanation I hardly know where to begin.
1st thing the router must be setup to go wireless, from a hard connection.  If you need help call the ISP support.  Find the newest netgear driver from the web download and save it.
2nd the wireless card is installed let windows do it.  Control panel or task bar at the wifi icon find your network.  Best to secure it.  WEP.  Write your network password down for future use!!!!!!!  They might not mention it but no spaces.  Example = a1a2b1b2c1 , it will be alphanumeric, ask the ISP for an example, change the example they suggest somewhat.
Try googling this topic or reading the PDF file.  This is an easy thing to do but read up first.
Profile: newbie
More Information
well i wanted to get a faster speed and i read somewhere that the wireless access point will get you the speed of that accespoint not your router
Profile: newbie
More Information
i can install it using the instructions but at first the wireless access point it doesn't even light when i connect it to the ethernet port
Profile: old hand
More Information
What is the speed of your wireless adapter? B or G?
Grumpy
Profile: newbie
More Information
the wireless adapter is b an old linksys model
Profile: old hand
More Information
Then your netgear wn802 wireless access point isn't going to be any faster. Both the wireless access router/point and the adapter need to be the same speed.
Grumpy
Add a reply
Google Ads
