Hi.
I recently bought MSI K9N Platinum and AMD 64 x2 3600+. The Processor is nice and overclocks extremely well, however I have a lot of problems with my mobo.
First It shutdowns whenever I try to change the processor voltage (no matter by how many even +0.05v)
I read about this problem and it turns out to be hardware problem with one of the capacitors. It seems I got the older revision and I am little screwed about it but anyway. My processor seems to overclock easy to 280Mhz bus which is about 2.66Ghz but after that my mobo dies. I think the chipset cant go over 280Mhz. Does anyone else have same mobo and tell me what overclock of the bus they achieved. I am limited by my multiplier and I feel bad that my processor can go much higher and my mb is the limit. I am overclockin the machine from Windows with the DualCoreCenter app because the BIOS is hell. Every time I change some value and save it turns off and I need to reset the bios.
I also bought a fan to blow on the chipset radiator in case the chipset fails because of overheating but this doesnt helped me achieve more than 280 Mhz. Also regretfuly there is no way I can up the chipset voltage as its not in the bios.
Does someone knows if a later bios can add chipset voltage setting or this depends on the MB make and it cant be done if its already isnt?
Thanks to all replies in advance
Regards (TG forums are the best )
