After many, many mods to my case, it is now at a loss for some crucial parts...
My main problem is that when my cpu fan is running full blast, I get an annoying rattling sound--- I think between the MOBO and Case. This is probably because I am missing about 5 screws to hold on the MOBO. Although it could be that the case is damaged I feel that I should atleast try and find some screws to secure it before something (like the cpu heatsink) rattles off and causes some damage.
So if someone happens to know of a link to buy extra case screws...
I live in a town 81008 for shipping purposes. I have staples, office depot, office max, and Circuit City, but no Best Buy or Comp USA.
I'm using a P4, 3.4 ghz stock heat sink
intel d915pbl mobo (don't recall what the case model is -- bought off newegg 4 years ago)
Any suggestion on how to fix or mod this or links would be appreciated, thanks-- Ben
Sponsored Links
A screw is a screw. Any hardware store will have what you need. Just bring one of them in with you so you get the right sixe.
-xcpus
Reply to apt403
I would hurry and get that fixed as soon as possible. A rattling mobo is a disaster waiting to happen. You could crack the mobo or short it out and ruin some of your components.
Reply to jjnguy13
Home Depot, Menards, Walmart, Sam's Club, Newegg, Frozencpu, CrazyPC, Xoxide, MnPcTech and etc. Lost of screws and you can replace just about every screws and nuts in the case.
But for sure Frozencpu, CrazyPC, and Xoxide sell parts for case modding so you more likely to get what you need there.
Reply to chuckshissle
- 0 +
Thanks for the help guys, couple follow up (stupid) questions.
Are the little washers important?? If not i'll got to the hardware store.
If they are, does anyone know what to ask for... as in the 4mm, 6mm... fine or course?
Sorry if these are stupid questions but i'd like to prolong this case on MOBO for another 6 months to a years.
On a another subject: Thanks to mpilchfamily for your help on a choice of powersupply from a previous post. I ended up buying an Antec True Power 650 watt (with 3 12v rails) $90 bucks after rebate.
and thanks for everyone else's imput on this problem --- this site is invaluable and I try and help if I ever know how too
Reply to bc4
Quote :
and thanks for everyone else's input on this problem --- this site is invaluable and I try and help if I ever know how too.
That is the mindset that every member of a forum should have!
Reply to jjnguy13
- 0 +
have you ever heard of blue tak, that is a great fix trick, seroiusly
Reply to dobby
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > where to buy extra case parts
There are 633 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
