will i encounter any problems by running 3 gigs of ram alone on vista 64 bit
5 answers Last reply
More about problem
  1. What do you mean by "alone".
    You will not have any problems running with 3 gigs.
  2. the impression i was given is that 4 gigs and up is all that a 64bit OS can run
  3. negative. it will work just fine
  4. A 32 bit OS can't use more than ~3.25GB of RAM. A 64 bit OS will utilize up to 128GB of RAM.
    Just make sure your motherboard will support your RAM.
  5. thnks
RAM Windows Vista
